https://easel.inventables.com/projects/r-RYwpme8zKtB5pkTllhqg
Hi could someone share some light on the attached file as to why when I go to run either the rough or detail cut I keep getting this error code
M32 Gcode file "0:gcodesDarrens Caterham Rough “not found”
This was a jpeg file I converted to a svg in Inkscape…1st time doing this.
All toolpaths look ok and it generates the code.
Thanks in advance for you time
