Hah I wiped up the actual blood befor the picture. Tho’s O’Flutes are sharp! I can’t wait to get it together and give Mach3 a workout. Thanks for the controllers by the way.
Ya it moves through osmosis.
Curtis, can you give a specific setup for getting Mach3 to run your machine? I want to switch over to it but have no idea how I use a breakout board or what hardware to get. I have a license for it which is why I’m looking to use it.
I wish I could help you out. I’m just getting started with it myself. From my understanding it’s a 48v power supply for the stepper drivers. A 5v power supply for the breakout board. And a stepper driver for each motor. For a basic setup. I’m starting out with a setup I got from @Earwigger. Maybe he can help out with particulars.
Hey @CoryMccormick - years ago, I started here. I bought their book and built my first CNC machine out of MDF, threaded rod and roller skate bearings. It was a GREAT experience. Fortunately for you, you only need to look through this list of tutorials and find those concerning motion electronics. It’s actually quite simple. I prefer Mach 3 with a parallel interface because it is all I know. I suggest you start with a USB interface and move on from there. Better electronics makes all the difference in the world. Once you get a USB based machine working - you will teach me and @CurtisCummings how to upgrade to Mach4.
https://buildyourcnc.com/CNCandLinearMotionRelatedTutorials.aspx
Care to share the file for the y axis upgrade?
I can see what I can do. I made them in Aspire. So I’ll have to see how I can export them. They create an additional 3" of clearance below the gantry. Unless you’ve up graded to the 5.75 Z Axis (search for Phils Z axis upgrade) they’ll be to tall for your stock Z.
Hmmm… Cant seem to figure out how to upload an SVG File…
Thanks so much I’m gonna get parts ready for the upgrade
I want to be able to laser engrave fatter things that’s all the z upgrade will come in due time. What bit did you cut these with?
Woah
How will you handle backlash? Just curious.
Mach 3
I like it! What is the width?
15 x 15 mm Perfect to mount to the support rail under my Y Axis rails. Ill have to cut new X Plates to move the motor down.
