Finding center question
does the Z probe just find Z height or can it also find center of the work piece? Id like to set up the X carve to use center of work piece instead of using the bottom left corner as home? is this possible?
Hi
The easyest would be to bring out a ruler and mark the center. Then jog your machine to the Mark and home it there.
thanks, ill give that a try .
The Triquetra Tool Box will generate zeroing gcode that will zero all three axis to any location you choose. Front left, Front right, or any other offset. Here is a screen shot of one of the generation pages.
