New to x carve.
Everytime I’ve attempted the finishing cut the machine starts and goes across the project and buries itself in and loses its mind??
I had the same issue. I found out by homing the machine before starting the project solved the problem.
I restarted the whole thing over. Now easel went let me changed which bit is going in in the finish settings
You should home your machine before each new project, just to be safe.
