First fusion 360 project (cw flash)
Im super lost on tool paths and if anybody can take a quick look as see if I’m missing anything
@RudyQuiroga Looks like you have some roughing toolpaths. Are you going to use a ballmill to finish the piece?
Don’t have any ball end mills …I ran all tool path with a flat end endmill
I see that. As you have it, you’re just generating roughing toolpaths that will create a stepped version of your design. You’ll need to add some finishing strategies to give it a smoother look. A ball end mill would help as well.
ok I’m slowly starting to get it lol … so should I add 3d parallel cut with a double edged ball nose? Which I apparently bought some time ago. ( amazon prime problem)
ok after spending some time looking up videos and tutorials. according to the simulation look like I got a smooth finish
