First attempt at half-toning
Whatcha think??
I’d be happy with that as a first attempt More details how you achieved this would be appreciated
Hey, @MickZebra, I used HalfToner V1.6 by @JasonDorie ( thanks ).
The material is MDF that was sprayed with 2 coats of black spray-paint.
NOTE: You need a v-bit, I used a 90* Freud 1/4" bit.
https://www.amazon.com/gp/product/B00004T7DZ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
NOTE 2: Download and extract halftoner V1.6 (or whichever you’d like) to an accessible location
TIP: Before you save the code, make sure the millimeter (Units) is selected.
Not sure if it is just me, but I was having issues with the values not converting from inches correctly.
NOTE: when you download the zip file, make sure you start with the (Start- or Start Windows) depending on your OS
NOTE 2: When connecting select your port and set baud to 115200 and open
TIP: Make sure when you zero your machine to your work, you reset X,Y,Z in the machine control tab.
These carves take a substantial amount of time to carve, however, you can speed things up when you get more comfortable with how everything works.
That is so cool.
That turned out great! (Particularly for a first attempt)
Dead man tells no tales
