New to easel have a question about project i am ready to carve. When doing a two stage carve and waiting to cut the outline will it automatically be cut out completely and leave the taps. Thank you for your response here is the project Easel - live to ride
Your outline is on the last page, remove the detail bit so it only uses your 1/8" bit. Basically it will be a three step carve.
Also look at your settings, you can change to a 1/4" bit, increase your plunge rate, decrease your feed rate and increase your depth per pass. will cut a lot of time off
Thank You for the reply and the instructions
