I am trying to curve my first sign. Do you have any comments on my settings, please? Does it look ok? Do I use the right bits for the sign?
Would you check my project file to see if everything is in order, pls? https://easel.inventables.com/projects/soROHBgd5oMulA7xaarpdw
Your feed rate is a bit high, what are your depths?
Bob & Amy, The - 1/8"
Insert background - 0.05055 in
Hard Maple
This one ran for 1:10 roughing, 1:24 Detail
“Doug Lisa” 0 depth
Background .15 depth
everything else .05 depth
Every machine is different I stiffened have my rails. I could probably push it harder but I get better results at these speeds.
