Still very new to this. Used Easel to create a “Stacked” carve.
Used 2 bits. Rough pass was a 1/4" down cut bit. Finish was a 1/16" up cut.
Everything seemed to go well. No movement on the bit change. Reset the z on the bit change.
This was just a test cut.
If you look at the pictures you will see a couple areas that did not get finished to the final depth.
Left side of the “D” and “T”
between the G and the A
Between the A and the Y upper area
Between the V and the E.
Is this something that i did wrong?
If this is something with Easel, how do I correct it?
I am using Firefox as the web browser.
That looks great. I just tried my first stacked carve the other day as well. It was much easier than I thought it would be and opened my eyes to a lot of new possibilities.
I just purchased a down cut bit that I was told would eliminate some of the imperfections in mine.
