Just came home for lunch break in an attempt to call Inventables, but the nice receptionist said all techs were busy so I had to leave a callback number.
@LarryM I just followed your steps (from my slow PC) and was able to do those steps to get Grbl uploaded. I then quit the Arduino app, opened Firefox and went to Easel Setup, and I got one step further!
After clicking Confirm Settings, putting in the port number (doing this from the PC for now) it now says “Configuring Z axis for ACME…”
But now it’s been sitting on this screen for a while. I also heard of people with Firefox problems, so I opened the setup in Chrome and had the same results
Also, as previously requested, I now could do the $$ command in the Arduino app and got the below code:
Grbl 0.9j ['$
Grbl 0.9j ['$' for help]
['$H'|'$X' to unlock]
$0=255 (step pulse, usec)
$2=255 (step port invert mask:11111111)
$3=255 (dir port invert mask:11111111)
$4=1 (step enable invert, bool)
$5=1 (limit pins invert, bool)
$6=1 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=2147483.648 (junction deviation, mm)
$12=2147483.648 (arc tolerance, mm)
$13=1 (report inches, bool)
$20=1 (soft limits, bool)
$21=1 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=255 (homing dir invert mask:11111111)
$24=2147483.648 (homing feed, mm/min)
$25=2147483.648 (homing seek, mm/min)
$26=255 (homing debounce, msec)
$27=2147483.648 (homing pull-off, mm)
$100=2147483.648 (x, step/mm)
$101=0.000 (y, step/mm)
$102=0.000 (z, step/mm)
$110=2147483.648 (x max rate, mm/min)
$111=0.000 (y max rate, mm/min)
$112=0.000 (z max rate, mm/min)
$120=2147483.648 (x accel, mm/sec^2)
$121=0.000 (y accel, mm/sec^2)
$122=0.000 (z accel, mm/sec^2)
$130=2147483.648 (x max travel, mm)
$131=0.000 (y max travel, mm)
$132=0.000 (z max travel, mm)
ok
Edit: Just tried on Mac. Get the same results. Can now do $$ in Arduino and get a response, and Easel Setup now gets to the Configuring Z axis for ACME… step
Still no green LEDs on, though
