Hi Folks,
I have an SVG, the problem is I need the red and blue separated so I can draw the blue, and only carve the red.
Any help would be sincerely appreciated.
Thank You
Martin Gutzmer
Here you go, Martin. You should download and start learning to use Inkscape.
As I said before, this design is setup to be laser cut. You might be better off designing your own, based on the general idea.
Hi Neil, thank You!
Did you happen to save these as SVG files?
If you did, could you please send them to me at mrgutzmer@gmail.com?
Thank You so very much!
God Bless,
Martin
Hey Martin,
Those are SVGs.
Right click–>Save as
Hi Neil,
I am downloading Inkscape, and will try to figure out to use it.
Thank You Again for your help.
God Bless,
Martin
Martin check your email
Anytime.
Feel free to ask Inkscape questions.
