After choosing a front using Easel Pro can you change the letters depth and width.
You can change the depth & the size.
Select the text and you’ll see a popup with cut settings and a tab for size adjustments.
And by using the offsetter app you can kindof adjust the width or thickness if the text.
To use the apps select the Lego button and locate the offsetter or offsetter v2 app.
