Food safe pigments
Has anyone here done cutting boards with a poured 2-part epoxy inlay? And if you tinted it was the tint “food safe”? And where did you find a supply…
Hey, I User the epoxy from artresins and tinted it with food-coloring. I use for example the Wilton icing colors, buyed on Amazon.
@ChristophStieler… Does the resin react differently as opposed to when you use a dry medium pigment? I’ve read about using food coloring but it stumps me how that would work due to the fact the food coloring is water based…
@KeddyKleinbergs No, you just use a pinch of food coloring. For example, when i mix 50 g ( 25 g hardener, 25 g resin) i use only the tip of a screwdriver, only very slightly moistened. The food coloring is very high concentrated.
