I need to sell my X-Carve. I’ve got everything listed below, it’s the complete kit. It will still need some configuring, but everything should work just fine. Ideally I’d love to sell it to someone locally (Tulsa, OK), but I can pack it up and ship if need be. I purchased this for a little over $1200, please make an offer.
Contents:
X-Carve
X-Carve 1000mm Rail Kit
X-Carve ACME Lead Screw Kit
X-Carve 1000mm Waste Board Kit
X-Carve NEMA 23 Stepper Motor Kit
X-Carve 300W 24VDC Spindle Kit
X-Carve Arduino/gShield Motion Controller Kit
X-Carve Power Supply Kit
X-Carve 1000mm Wiring Kit
X-Carve 1000mm Drag Chain Kit
X-Carve Limit Switch Kit
X-Carve Tool Kit
X-Carve Clamp Set
X-Carve End Mill Starter Set
More Details
X-Carve® X-Carve Core Components X-Carve 1000mm Rail Kit Black MakerSlide, support extrusions, GT2 belts, brackets and hardware X-Carve ACME Lead Screw Kit ACME lead screw, Delrin nut and hex nut X-Carve 1000mm Waste Board Kit Waste board with threaded inserts and hardware (clamps not included) X-Carve NEMA 23 Stepper Motor Kit Four 140oz-in stepper motors, pulleys, hardware X-Carve 300W 24VDC Spindle Kit 24V 300W spindle, custom mount, cap, wrenches, hardware X-Carve Arduino/gShield Motion Controller Kit Arduino, gShield, enclosure, fan, USB cable, wire, hardware X-Carve Power Supply Kit 24V / 16.7A / 400W Power supply, interface PCB, power cord and hardware X-Carve 1000mm Wiring Kit Cable, terminal blocks, hardware X-Carve 1000mm Drag Chain Kit Drag chain, mounting brackets, hardware X-Carve Limit Switch Kit Switches, wire and hardware X-Carve Tool Kit Tools for assembly, including various wrenches, screwdrivers and safety glasses, all in a durable pouch X-Carve Clamp Set Secure material to the waste board while carving X-Carve End Mill Starter Set Five 1/8" shank milling bits with 1/32", 1/16" and 1/8" cutting diameters (not compatible with default 1/4" collet in Dewalt 611)
