So I purchased this unopened from another member here:
I’ve had a ton going on (work and family) and have not had time to think about it.
As such, the X-carve 1000mm remains boxed and untouched.
I’d be interested in selling to a member in the Brooklyn or NY area.
Everything from the original posting still holds:
Description from Order Receipt
X-Carve 1000mm Rail Kit Black MakerSlide, support extrusions, GT2 belts, brackets and hardware X-Carve ACME Lead Screw Kit ACME lead screw, Delrin nut and hex nut X-Carve 1000mm Waste Board Kit Waste board with threaded inserts and hardware (clamps not included) X-Carve NEMA 23 Stepper Motor Kit Four 140oz-in stepper motors, pulleys, hardware X-Carve 300W 24VDC Spindle Kit 24V 300W spindle, custom mount, cap, wrenches, hardware X- Carve Arduino/gShield Motion Controller Kit Arduino, gShield, enclosure, fan, USB cable, wire, hardware X-Carve Power Supply Kit 24V / 16.7A / 400W Power supply, interface PCB, power cord and hardware X-Carve 1000mm Wiring Kit Cable, terminal blocks, hardware X-Carve 1000mm Drag Chain Kit Drag chain, mounting brackets, hardware X-Carve Limit Switch Kit Switches, wire and hardware X-Carve Tool Kit 10 tools for assembly, including a T25 Torx driver, various wrenches and safety glasses, all in a durable pouch X-Carve Clamp Set Secure material to the waste board while carving X-Carve End Mill Starter Set Five 1/8" shank milling bits with 1/32", 1/16" and 1/8" cutting diameters (not compatible with default 1/4" collet in Dewalt 611) X-Carve Digital Calipers Measure the exact thickness of the material you’re carving X-Carve® X-Carve Core Components
Includes wasteboard
