I was carving a project that involved V-bits with ramping on. When I generated the toolpath, the path looked like it “ramped” up through empty space and was set to carve through the project. This only seemed to happen with manual cut settings and with ramping turned on. Example Buggy Project
@GregMacon, I’m the Director of Marketing from Inventables! Thanks for sharing this. Please reach out to help@inventables.com and a member of our Customer Success team will help you with this.
To add to the OP’s report, this occurs on the tenth stepdown of the leftmost square pocket and traverses through the material to the other square on the right. This should have been a move to Safety Height and then over to the right-most square just like all the others.
{:0)
Brandon Parker
