Fragile earrings / pendants: how to finish these?
I’m really pleased that these came out so well. This is 3/16" walnut. They are fragile; I broke two just getting them free of the tabs, which I did with a scroll saw. Now, how to put an attractive finish on these guys? I have an alligator-clip clamp to hold them, but I don’t know if hand-painting with a tiny brush is a good idea, and I doubt that using a spray can would come out very nicely. I don’t have much experience or knowledge with finishing and don’t know what would be best. What would you do?
Have you every tried wood hardener? It will make those stronger. Not sure the finish it leaves on that
Oh and those are beautiful.
How about a tung oil finish?
I have used it on walnut before with good results. (The stuff from the local hardware store, I haven’t managed to pick up real tung oil yet.)
It also hardens in the wood to add strength.
I agree on the tung oil finish. I use it all the time, it will soak in and harden the wood a bit, leaving a nice matte/satin finish. It really protects the wood and brings out the wood grain and color.
Thanks, all. On the way to get some tung oil now.
I found this.
I second the boiled linseed oil recommendation. Easy to use, easy refresh at a later date and nearly impossible to do wrong. Only thing is on open pore woods like oak, and to a certain extent walnut, it can seep for awhile and should be wiped off to prevent it drying “goopy”.
Thanks for all your help. I went after tung oil and wound up getting Danish, as it was half the price. I have the first batch drying now. I will also try boiled linseed oil. This is a good chance for me to have a learning experience, since the “test products” will be identical. I’ll show results on here.
I’ve had great results using a mixture of tung oil, spar varnish and turpentine. Boiled linseed oil will also work, for the initial coats I mix 50% turpentine 25% varnish and 25% oil. Soaks in better/faster. Later coats I mix about equal parts. On open pore woods wet sanding with 220 or finer produces a slurry that fills the grain somewhat. Apply with a rag, brush, or dip small parts, Let dry till the surface starts to look dry in spots, then wipe remaining finish off.
Always dispose of the rags properly, spontaneous combustion is real.
