Easel keeps freezing when I try to simulate my detail toolpaths. I can’t create any gcodes for my projects. I thought maybe it just needs more time but this is not the case. I left it and over 10 hours later, the progress bar hasn’t moved. Please help, as I cannot create anything now.
Typically this is because the Vbit is either entered incorrectly (the incorrect width is entered as this i supposed to be the widest part of the cutter not the tip width and this is often misunderstood) OR there is a LOT of flat portions and the carve should really be setup as a 2 bit carve using an endmill for the majority of the flat portion. . .
Hi Janine, you may want to click the “forum” button at the top of this page, then the “+ New Topic” button in order to begin a new thread to address your issue specifically. If possible identify what model cnc this is regarding as well. thanks!
