When I do a v-carve calculation in F-Engrave, and export the g-code, the g-code cannot be opened by easel.
it says:
Line 76: G91.1
The file contains invalid G-code syntax.
I am using Easel with a Carvey
it says:
Line 76: G91.1
Look in the general settings on F-Engrave. There’s some start and end G-Code in there. Delete that.
Also, I set the Arc to none.
thanks!
Mentioned in a blog post: Using F-Engrave with GRBL (ShapeOko) | Scorch Works Blog
- Use F-Engrave version 1.49 or higher
- Select the “Disable Variables” check box in the F-Engrave “General Settings” window
- Un-select the “Enable Arc Fitting” check box in the F-Engrave “General Settings” window
- Select “Suppress Comments” in the F-Engrave “General Settings” Window
nevermind.
