G code file for taller end plates?
Good evening all,
After making a right balls of two attempted tailed end plates, I was wondering if anyone had any g code files they wouldn’t mind sharing for taller y axis end plates… obviously no worries if not, I know people don’t always like sharing their hard earned CAM files… or if anyone could suggest alternated ways of manufacturing them (i.e. by hand)?
Cheers,
Simon
never use someone else g-code. you will never know what you got until it is too late.
here is a project file that I used to make some end plates. I used the extra maker-slide left over from the upgrade to the one piece x-axis. so I have two maker-slides per Y-axis and I always planed on making a brace but they are very strong like this.
brilliant, thank you for this… and some good advice!
Are these +2?
@JuanDeLaO from my measurements it should be right at 3 inch increase in height.
also I would modify them now to fit the dust shoe I got from Invetables. I had to remove about 1/4 inch from the side on the one plate to keep the dust boot from hitting it.
Thank you sir!
