Hi Back after some time with the X Carve, If I’m importing g code into Easel, i get a warning notice from Easel re the g code. There are two options which should I pick?
Cheers
Have you downloaded the Easel post processor and installed in into Aspire? The “X- carve” one isn’t compatible with easel. You can find the correct one by selecting gcode import in easel and selecting the “vectric” grey tab at the bottom.
thx Seth that was the problem. I re cut the job and it was fine.
Thanks mate
Cheers
Guy
