Try typing your header 1 line at a time (or copy and paste) into UGS and send the commands to the machine and see if you get an error on any line…I would change output to verbose.
There is a setting in UGS to output verbose (more info) while it runs commands…I think it is just a check box.
I think the issue is the G64 command…but I have been wrong before
@PhilJohnson As mentioned by @EricDobroveanu I believe G64 and P0.001 is not supported in Easel’s Gcode import, or by GRBL.
Remove that from the F-Engrave configuration.
GRBL will reject the WHOLE LINE of code when it receives a command it does not like.
I gotcha, but grbl does not support G64.
That chart is great, but like already stated, GRBL only supports what it supports. Not all CNC machines support all those codes.
also remove the P0.001 as that goes with the G64.
No reason, but it won’t matter.
So, no…it only needs to be in there once, but having it twice won’t make a difference.
G91.1: Arc IJK Distance Modes
It is supported in grbl as of version 0.9i
Found this…it is an older article, but may be relevant…
First, F-Engrave defines variables for the feed rate and engraving cut depth that are not compatible with GBRL. This problem can be solved by checking the “Disable Variables” check box in the F-Engrave Settings window. This will prevent F-Engrave from writing the incompatible variables to the g-code output file.
Second, F-Engrave uses incremental distance mode for arcs. In order to ensure that g-code interpreters read the data correctly the code G91.1 is set in the g-code output (setting the arc distance mode to Incremental). Unfortunately GRBL does not support reading the G91.1 code. To eliminate the incompatible G91.1 code from the F-Engrave output F-Engrave users need to un-check the “Enable Arc Fitting” option in the F-Engrave Settings window. (Alternatively the G91.1 code can be manually removed from the g-code file.)
