I am trying to learn VCarve Pro and use Sketchup to create 3D content. I am designing a bench and have created a couple of very simple templates for the legs. When I attempt to import the G Code from VCarve into Easel it either doesn’t load or when it does it doesn’t show any tool paths, so a blank board. When I close out Easel it show under my projects that I have created the project with a thumbnail with the part in place. When I open it I get the error message, “I is not a function.” I am completely stuck. I have been able to import very complex gcode tool paths saved from VCarve Pro that I have created from STL files I have purchased. Anyone have any idea why this is happening and any fix to the problem?
Thanks
Because it is such a simple 2D template I made it in VCarve and am still running into the same problem. Validation never stops and when I close validation out it shows that I have the file available under my projects, but no tool paths when I open it up.
