Nope. No need so far. No finances. No space on my granite table top. So far no jobs have required anything larger then what i can handle. Do i wanna? DEF!
I like the concept but Iām not sure how much I like the durability. By extending yet not strengthening the X axis end plates you are essentially putting a lever arm on the end of them; Your relationship to the fulcrum has changed and weakens the rigidity. It would be wiser in my opinion to either replace the endplates with thicker material all together, or replace the Y axis endplates to gain the height instead.
Iām glad it worked out for you. That was just my initial impression looking at the design. Thanks for the idea!
I cut and installed Philās plates as well. After installation, I donāt get any added play from the increase in height.
Is there ANY way in which you would be willing to share the file, and material type? This is DEFINITELY the direction which I would like to go with my end plates.
Everything you want is up there somewhere.
Thank you for your insight. As you apparently know this to be fact, would you care to show your evidence?
Iām totally down for an 1800ā¦
LOL
14 posts above
You are telling me that there is a file for Phantommās āEnd Platesā, 14 posts above???
Ah, well the answer to that question is up there also. Besides itās pretty simple to get the spec sheet and make your own.
As I asked for a file, and not a billion reasons on why I should not asked for a fileā¦ I am going to go ahead and disregard you at this point.
Well , Iām not sure how it went down that road. But ok. Iāll try and not let it affect my sleep tonight.
Now, now children. Play nice!
Wasnāt trying to āPhilā him lol. Just point him in the right direction. The PDF from Inventables makes if pretty easy to to make your own. Iām not sure how to feel. Iāve never been ādisregardedā before.
Hit the brakes peepsā¦ Still working out the deeeeeeetails on this plate-a-majig.
Thatās what I was sayingā¦
Hey! how about those Cubbies!!!
Phil:
Had an interesting thought about the lift plates.
What about a thin plate on the opposite side to help lock it down better?
I am talking about the inset part, you have a thin matching plate and use that to help secure it.
What do you think. Too much weight? or will it matter? I have not experimented with them yet.
PLEASEā¦ tell me this is shared on easel or something. Please say that you have a link to this or are willing to upload.
