Making a outline offset 40% bigger than the profile cut then making the step over 40% produces a wider pocketing cut “channel”, using 2 passes without a huge increase in overall cut time.
I am guessing this makes for easier chip clearing, and it would help if it was a run out issue.
Does anyone know more about this approach? Why it is done and how much wider should the channel be than the bit?
Found a post with more info on profile cutting aluminum:
Aluminum Paintball Trigger Plate(s) - Cut and Anodized
Nice, that’s the one I was remembering (the video of that). Now the question is, does your CAM software have that option?
No, but I can manually make the outline into a pocket with the offset tool. A bit clunky but it works.
I did a quick test of using pocket strategy to do the profile cut in a unused space on the material.
I made a offset outline 40% of the bit diameter around my test object (bat symbol) and did a pocket cut with a 40% step over so it would do it in 2 passes.
Cut at .39mm depth, 1016 mm/min, 18,000 rpm
I wet with WD40 and vacuumed up chips
I did the pocket cut for the first 90% of the material, then switched to a traditional profile strategy with tabs for the remainder. I could not make tabs automatically happen with the pocket cut, but I think I can manual add them in if I want.
It worked fine. No broken bits, no bad “sounds”, Lots of chips and mess.
Now to run the bracket print. That will take about 4 hours so I may wait till the weekend as I need to monitor it closely.
Dude! That looks great! I’m looking forward to seeing those gantry plates.
I finished cutting the plates last night, using the pocket cut approach worked perfectly.
I also re-did the original profile cut on the first bracket as a pocket cut and finished cutting it out as well.
2 of the 4 eccentric spacer holes on the bottom of the bracket are a bit too small. I am not sure why just those 2 are different, I will have to check my cut file and see if there is a reason for that.
But I should be able to drill and sand them out to fit.
Hopefully I will get a chance to bolt this all together this weekend.
I did just realize that I don’t have a spindle mount for the c-beam. The one I ordered will not hold the Makita.
So I will either have to adapt the XC spindle mount, make one, or order one. More research.
Looks like a beast! Very clean edges, nice. How much did the AL plate cost you?
I am not sure as my local metal supplier sells cut aluminum remnants by weight. I got 2 plates for about $45, This plate was a little thicker so, around $25
I was lucky, the remnants are a lot cheaper if they have one in a size / thickness / grade you can use. Otherwise there is a cutting fee of $10 per cut plus the specific material cost. (The 6061 costing more than then 5052)
Our cnc machines at work use 20mm linear rods for the sliding doors in a span of around 36 inches. I also had thought about using linear rods so out of curiosity pushed in at about the middle it seems to flex very easy so I decided I will not be converting to rods. Just my experience.
Yes I added wheels. There may be some alignment issues if my bracket is off. Worse case I may not be able to align all of the wheels to be effective, but I figured it was worth a try.
The extra wheels do reduce my total Y axis work area, but the plan is to extend the Y axis next.
I have noticed that a lot of the OX and c-beam designs add additional pairs of wheels to help distribute the load. The Z axis C-beam actual has 16 wheels, 4 pair on the outside and 4 pair on the inside.
You’re also not rubbing the backside of the bit as it cuts a groove.
Openbuilds sells set screw type shaft collars. You may want to use clamping shaft collars. Same with the beam couplers. Set screws can be evil.
The replacement wheels came in so I resumed working on the upgrade.
I drilled and taped (where needed) the plates, and started to put it all together.
It is starting to look like a gantry
I need to rewatch the assembly videos especially for the Z axis as I am having bit of trouble following the written instructions on setting up the locking rings properly.
I am starting to review my TinyG configuration settings of the upgrade and I noticed that the c-beam screw drive max feed rate is a lot higher than the XC.
6000mm/m Max, 1500mm/m recommended.
For the X axis this will be a significant slow down from 8000mm/min.
But a big speed boost for the Z axis from 500mm/min.
I have noticed that cuts with a lot of Z axis movement were slowed down by this limitation.
I had been avoiding spiral cut smoothing strategies on my profile cuts for this reason.
It will be interesting to see how the increase in Z axis speed offsets the loss of X axis speed.
Oh heck… I bet this explains the strange behavior I was seeing on helical cuts coming out of Fusion360. Maybe that software assumes a faster Z-Axis rate of travel.
Aaron - not sure if it is too late in your build but have you looked at these?:
You’ve got a great machine going there and since I have switched to this type of z-axis, the results are night and day. There are several models and I recommend the “fast travel” type.
Also, for chip clearing, this is less than $15 and I hardly ever have to use WD-40 anymore. Just point it down at your bit and the chips will blow away:
http://www.amazon.com/Yosoo-Coolant-Lubrication-Milling-save-energy/dp/B00ZOQ6X10?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage
It is too late to change the Z axis now, not without making new gantry plates.
Initially I was trying to go with off-the-shelf parts so I had more options about the Z axis, but it was really tricky to lay out. So I went with this style because the gantry plates were already designed and there was a full part list to work off of.
I like the mist wand, I am planing on getting one down the road. I would use one now but I have to replace my air compressor first.
I had to replace mine too - I had a cheap pancake compressor that was 2x louder than the x-carve and shopvac together. I found California Air tools - ultraquiet compressor and built it into a cabinet. Nice and quiet. If you end up with that mister, Lowes sells a kit…
http://www.lowes.com/pd_498367-47120-SGY-AIR201_1z10r73__?productId=50129864&pl=1
that will snap right into that loc line fitting for ease of connection, plus you get a cool yellow coil thing sticking out of the top of your machine.
