Just wanted to share some of my projects.
All of this may be repetitive for experienced users. Hopefully some of the many newbies will get something out of this.
This 5x5x8 box uses the Box Maker App. I planned the box for 3/8 thick wood. I planed down a dozen cedar fence pickets since I plan to make a bunch of boxes this size. One 6 ft picket will make 1 box with about 12 to 18 inches left over. My boards planed down to .450 inch thick, I added .005 to be sure. The app automatically adjusted the slots to fit. At least I think that is what happened.
Each side of the box was cut as a separate work piece. I cut 2 6x6 pieces and 4 6x10 pieces. I put a block on the waste board to act as a location for the work piece so the ZERO would be the same for each piece.
As each piece was finished I removed it and loaded the next piece. The ZERO always remained in the lower left corner of each work piece I did the lid last because I wanted to engrave a logo on it. These photos are the unfinished box fresh from the machine.
Thanks,
βGβ
