Hi, I’m so new that I haven’t managed to make my first proper engraving yet.
I have a few problems and questions that I would appreciate some guidance.
Info:
CNC: Sainsmart 4030 pro 500 x 500 mm
Board: PCB, 1 copper layer, total thickness of 1.6 mm
Board size: 300 x 300 mm
Cut depth: 0.1mm
Problem 1:
I do my designs in SketchUp then save as PNG.
I import into Easel to generate gcode and then I’m using Candle to mill (as I could not figure out how to use the z probe with Easel for the moment)
The process was taking for ever, going like 100 times around a circle shape!!! Ridiculous!
I then used ncviewer to try and find what was going on. The simulation showed that the gcode generated by Easel was causing this behaviour.
Question 1: Any reason why Easel is telling the cnc to pass "a million times " to make a basic 0.1mm depth circle? I’m happy with 2 or 3 passes max.
Problem 2:
I imported the file again and this time I run the simulation. it estimated 96 hours!!! I’m trying to mill about 50% of the copper in the above PCB.
Question 2:
Is this normal in this cnc world? I might as well just cut inside shape path , paint protect the copper shape and use chemicals to eat the remaining copper away. This cnc part takes 20 minutes to do this.
Problem 3:
The z probe zeroing is not well explained in Easel. I should have command buttons in the screen to lower the z axis to touch the based of the probe.
Question 3: is there any guide to use z probe with 4030?
Question 4: Any guidelines, references on parameters, speeds, feed, nccode techniques to mill drawings in blank PCBs? (I’m not using GRBL PCB files, just drawings).
Thanks
Pablo
You may want to post the first 20 lines of gcode for us to take a look at.
I assume the tip diameter specified for the gcode generation is very fine, and since stepover often is given in percentage (like 5%) a lot of paths are needed to clear the area.
Think ant sized miniature lawnmower for a golf course.
The stepover was set by default to 40%. Could this be the reason?
Sure, that would be highly appreciated. Here are the first 1000 lines, which do the same, just pass around a circle many times.
G21
G90
G1 Z3.810 F228.6
G0 X165.712 Y45.150
G1 Z-0.100 F228.6
G1 X161.106 Y47.392 F254.0
G1 X160.158 Y48.035 F254.0
G1 X157.093 Y50.385 F254.0
G1 X155.792 Y52.067 F254.0
G1 X154.951 Y53.596 F254.0
G1 X153.792 Y56.373 F254.0
G1 X153.384 Y58.107 F254.0
G1 X153.430 Y60.235 F254.0
G1 X153.867 Y62.008 F254.0
G1 X154.649 Y63.902 F254.0
G1 X155.597 Y65.692 F254.0
G1 X158.130 Y69.096 F254.0
G1 X159.638 Y70.383 F254.0
G1 X161.060 Y71.186 F254.0
G1 X162.777 Y71.982 F254.0
G1 X166.632 Y73.176 F254.0
G1 X170.626 Y72.978 F254.0
G1 X172.536 Y72.333 F254.0
G1 X174.299 Y71.486 F254.0
G1 X176.437 Y70.160 F254.0
G1 X177.757 Y69.177 F254.0
G1 X178.927 Y67.823 F254.0
G1 X179.692 Y66.448 F254.0
G1 X180.310 Y65.104 F254.0
G1 X181.473 Y61.753 F254.0
G1 X182.045 Y58.525 F254.0
G1 X181.675 Y56.896 F254.0
G1 X180.787 Y54.052 F254.0
G1 X178.054 Y49.751 F254.0
G1 X176.960 Y48.730 F254.0
G1 X175.586 Y47.637 F254.0
G1 X174.576 Y47.045 F254.0
G1 X172.146 Y45.999 F254.0
G1 X169.530 Y45.114 F254.0
G1 X166.878 Y44.916 F254.0
G1 X165.712 Y45.150 F254.0
G1 X165.713 Y45.152 F254.0
G1 X161.106 Y47.393 F254.0
G1 X160.159 Y48.037 F254.0
G1 X157.094 Y50.386 F254.0
G1 X155.794 Y52.068 F254.0
G1 X154.953 Y53.597 F254.0
G1 X153.794 Y56.373 F254.0
G1 X153.387 Y58.107 F254.0
G1 X153.432 Y60.235 F254.0
G1 X153.870 Y62.008 F254.0
G1 X154.651 Y63.901 F254.0
G1 X155.598 Y65.691 F254.0
G1 X158.131 Y69.095 F254.0
G1 X159.639 Y70.381 F254.0
G1 X161.061 Y71.185 F254.0
G1 X162.778 Y71.981 F254.0
G1 X166.632 Y73.174 F254.0
G1 X170.626 Y72.975 F254.0
G1 X172.535 Y72.331 F254.0
G1 X174.298 Y71.485 F254.0
G1 X176.437 Y70.159 F254.0
G1 X177.756 Y69.176 F254.0
G1 X178.926 Y67.821 F254.0
G1 X179.691 Y66.446 F254.0
G1 X180.308 Y65.102 F254.0
G1 X181.471 Y61.753 F254.0
G1 X182.042 Y58.525 F254.0
G1 X181.673 Y56.897 F254.0
G1 X180.786 Y54.053 F254.0
G1 X178.053 Y49.753 F254.0
G1 X176.958 Y48.731 F254.0
G1 X175.585 Y47.639 F254.0
G1 X174.575 Y47.047 F254.0
G1 X172.145 Y46.000 F254.0
G1 X169.529 Y45.116 F254.0
G1 X166.879 Y44.918 F254.0
G1 X165.714 Y45.155 F254.0
G1 X161.107 Y47.395 F254.0
G1 X160.160 Y48.038 F254.0
G1 X157.094 Y50.388 F254.0
G1 X155.795 Y52.069 F254.0
G1 X154.954 Y53.598 F254.0
G1 X153.795 Y56.374 F254.0
G1 X153.389 Y58.107 F254.0
G1 X153.435 Y60.235 F254.0
G1 X153.872 Y62.008 F254.0
G1 X154.653 Y63.900 F254.0
G1 X155.600 Y65.691 F254.0
G1 X158.133 Y69.094 F254.0
G1 X159.640 Y70.379 F254.0
G1 X161.061 Y71.183 F254.0
G1 X162.778 Y71.979 F254.0
G1 X166.632 Y73.172 F254.0
G1 X170.626 Y72.973 F254.0
G1 X172.534 Y72.330 F254.0
G1 X174.297 Y71.483 F254.0
G1 X176.436 Y70.157 F254.0
G1 X177.754 Y69.174 F254.0
G1 X178.924 Y67.820 F254.0
G1 X179.689 Y66.445 F254.0
G1 X180.307 Y65.101 F254.0
G1 X181.469 Y61.753 F254.0
G1 X182.040 Y58.526 F254.0
G1 X181.671 Y56.897 F254.0
G1 X180.784 Y54.053 F254.0
G1 X178.051 Y49.754 F254.0
G1 X176.957 Y48.733 F254.0
G1 X175.583 Y47.641 F254.0
G1 X174.573 Y47.048 F254.0
G1 X172.145 Y46.002 F254.0
G1 X169.528 Y45.117 F254.0
G1 X166.880 Y44.921 F254.0
G1 X165.715 Y45.157 F254.0
G1 X161.108 Y47.396 F254.0
G1 X160.161 Y48.040 F254.0
G1 X157.095 Y50.389 F254.0
G1 X155.797 Y52.070 F254.0
G1 X154.956 Y53.598 F254.0
G1 X153.797 Y56.375 F254.0
G1 X153.391 Y58.107 F254.0
G1 X153.437 Y60.235 F254.0
G1 X153.874 Y62.008 F254.0
G1 X154.654 Y63.899 F254.0
G1 X155.601 Y65.690 F254.0
G1 X158.135 Y69.093 F254.0
G1 X159.641 Y70.378 F254.0
G1 X161.062 Y71.182 F254.0
G1 X162.779 Y71.978 F254.0
G1 X166.632 Y73.169 F254.0
G1 X170.626 Y72.971 F254.0
G1 X172.534 Y72.328 F254.0
G1 X174.296 Y71.482 F254.0
G1 X176.435 Y70.155 F254.0
G1 X177.753 Y69.173 F254.0
G1 X178.922 Y67.818 F254.0
G1 X179.687 Y66.443 F254.0
G1 X180.305 Y65.099 F254.0
G1 X181.466 Y61.753 F254.0
G1 X182.038 Y58.527 F254.0
G1 X181.669 Y56.898 F254.0
G1 X180.781 Y54.054 F254.0
G1 X178.050 Y49.756 F254.0
G1 X176.955 Y48.734 F254.0
G1 X175.582 Y47.642 F254.0
G1 X174.572 Y47.050 F254.0
G1 X172.144 Y46.003 F254.0
G1 X169.528 Y45.119 F254.0
G1 X166.881 Y44.923 F254.0
G1 X165.715 Y45.159 F254.0
G1 X161.109 Y47.398 F254.0
G1 X160.162 Y48.041 F254.0
G1 X157.096 Y50.391 F254.0
G1 X155.798 Y52.070 F254.0
G1 X154.957 Y53.599 F254.0
G1 X153.798 Y56.376 F254.0
G1 X153.394 Y58.107 F254.0
G1 X153.439 Y60.235 F254.0
G1 X153.877 Y62.008 F254.0
G1 X154.656 Y63.898 F254.0
G1 X155.603 Y65.689 F254.0
G1 X158.136 Y69.093 F254.0
G1 X159.641 Y70.376 F254.0
G1 X161.063 Y71.180 F254.0
G1 X162.780 Y71.976 F254.0
G1 X166.632 Y73.167 F254.0
G1 X170.626 Y72.968 F254.0
G1 X172.533 Y72.327 F254.0
G1 X174.296 Y71.480 F254.0
G1 X176.434 Y70.154 F254.0
G1 X177.751 Y69.171 F254.0
G1 X178.921 Y67.817 F254.0
G1 X179.686 Y66.442 F254.0
G1 X180.304 Y65.098 F254.0
G1 X181.464 Y61.753 F254.0
G1 X182.035 Y58.527 F254.0
G1 X181.666 Y56.899 F254.0
G1 X180.779 Y54.055 F254.0
G1 X178.048 Y49.757 F254.0
G1 X176.954 Y48.736 F254.0
G1 X175.580 Y47.644 F254.0
G1 X174.570 Y47.051 F254.0
G1 X172.143 Y46.005 F254.0
G1 X169.527 Y45.121 F254.0
G1 X166.881 Y44.925 F254.0
G1 X165.716 Y45.162 F254.0
G1 X161.110 Y47.399 F254.0
G1 X160.162 Y48.043 F254.0
G1 X157.097 Y50.392 F254.0
G1 X155.800 Y52.071 F254.0
G1 X154.959 Y53.600 F254.0
G1 X153.800 Y56.376 F254.0
G1 X153.396 Y58.107 F254.0
G1 X153.442 Y60.235 F254.0
G1 X153.879 Y62.008 F254.0
G1 X154.657 Y63.898 F254.0
G1 X155.604 Y65.688 F254.0
G1 X158.138 Y69.092 F254.0
G1 X159.642 Y70.375 F254.0
G1 X161.064 Y71.179 F254.0
G1 X162.781 Y71.975 F254.0
G1 X166.632 Y73.165 F254.0
G1 X170.626 Y72.966 F254.0
G1 X172.532 Y72.325 F254.0
G1 X174.295 Y71.479 F254.0
G1 X176.433 Y70.152 F254.0
G1 X177.750 Y69.169 F254.0
G1 X178.919 Y67.815 F254.0
G1 X179.684 Y66.440 F254.0
G1 X180.302 Y65.096 F254.0
G1 X181.462 Y61.753 F254.0
G1 X182.033 Y58.528 F254.0
G1 X181.664 Y56.900 F254.0
G1 X180.777 Y54.056 F254.0
G1 X178.046 Y49.759 F254.0
G1 X176.952 Y48.737 F254.0
G1 X175.578 Y47.645 F254.0
G1 X174.568 Y47.053 F254.0
G1 X172.142 Y46.006 F254.0
G1 X169.526 Y45.122 F254.0
G1 X166.882 Y44.927 F254.0
G1 X165.717 Y45.164 F254.0
G1 X161.110 Y47.401 F254.0
G1 X160.163 Y48.044 F254.0
G1 X157.097 Y50.394 F254.0
G1 X155.801 Y52.072 F254.0
G1 X154.960 Y53.601 F254.0
G1 X153.801 Y56.377 F254.0
G1 X153.398 Y58.107 F254.0
G1 X153.444 Y60.235 F254.0
G1 X153.881 Y62.008 F254.0
G1 X154.659 Y63.897 F254.0
G1 X155.606 Y65.687 F254.0
G1 X158.139 Y69.091 F254.0
G1 X159.643 Y70.373 F254.0
G1 X161.065 Y71.177 F254.0
G1 X162.782 Y71.973 F254.0
G1 X166.632 Y73.162 F254.0
G1 X170.626 Y72.964 F254.0
G1 X172.531 Y72.323 F254.0
G1 X174.294 Y71.477 F254.0
G1 X176.433 Y70.151 F254.0
G1 X177.748 Y69.168 F254.0
G1 X178.918 Y67.814 F254.0
G1 X179.683 Y66.439 F254.0
G1 X180.301 Y65.094 F254.0
G1 X181.459 Y61.753 F254.0
G1 X182.031 Y58.529 F254.0
G1 X181.662 Y56.900 F254.0
G1 X180.774 Y54.056 F254.0
G1 X178.045 Y49.761 F254.0
G1 X176.950 Y48.739 F254.0
G1 X175.577 Y47.647 F254.0
G1 X174.567 Y47.054 F254.0
G1 X172.141 Y46.008 F254.0
G1 X169.525 Y45.124 F254.0
G1 X166.883 Y44.930 F254.0
G1 X165.718 Y45.166 F254.0
G1 X161.111 Y47.403 F254.0
G1 X160.164 Y48.046 F254.0
G1 X157.098 Y50.395 F254.0
G1 X155.803 Y52.073 F254.0
G1 X154.962 Y53.601 F254.0
G1 X153.803 Y56.378 F254.0
G1 X153.401 Y58.107 F254.0
G1 X153.446 Y60.235 F254.0
G1 X153.884 Y62.008 F254.0
G1 X154.660 Y63.896 F254.0
G1 X155.608 Y65.687 F254.0
G1 X158.141 Y69.090 F254.0
G1 X159.644 Y70.372 F254.0
G1 X161.065 Y71.176 F254.0
G1 X162.782 Y71.972 F254.0
G1 X166.632 Y73.160 F254.0
G1 X170.626 Y72.961 F254.0
G1 X172.531 Y72.322 F254.0
G1 X174.293 Y71.475 F254.0
G1 X176.432 Y70.149 F254.0
G1 X177.747 Y69.166 F254.0
G1 X178.916 Y67.812 F254.0
G1 X179.681 Y66.437 F254.0
G1 X180.299 Y65.093 F254.0
G1 X181.457 Y61.753 F254.0
G1 X182.028 Y58.530 F254.0
G1 X181.659 Y56.901 F254.0
G1 X180.772 Y54.057 F254.0
G1 X178.043 Y49.762 F254.0
G1 X176.949 Y48.740 F254.0
G1 X175.575 Y47.648 F254.0
G1 X174.565 Y47.056 F254.0
G1 X172.141 Y46.010 F254.0
G1 X169.525 Y45.125 F254.0
G1 X166.884 Y44.932 F254.0
G1 X165.719 Y45.169 F254.0
G1 X161.112 Y47.404 F254.0
G1 X160.165 Y48.047 F254.0
G1 X157.099 Y50.397 F254.0
G1 X155.804 Y52.074 F254.0
G1 X154.963 Y53.602 F254.0
G1 X153.805 Y56.379 F254.0
G1 X153.403 Y58.107 F254.0
G1 X153.449 Y60.235 F254.0
G1 X153.886 Y62.008 F254.0
G1 X154.662 Y63.895 F254.0
G1 X155.609 Y65.686 F254.0
G1 X158.142 Y69.090 F254.0
G1 X159.645 Y70.370 F254.0
G1 X161.066 Y71.174 F254.0
G1 X162.783 Y71.970 F254.0
G1 X166.632 Y73.158 F254.0
G1 X170.626 Y72.959 F254.0
G1 X172.530 Y72.320 F254.0
G1 X174.292 Y71.474 F254.0
G1 X176.431 Y70.148 F254.0
G1 X177.745 Y69.165 F254.0
G1 X178.915 Y67.811 F254.0
G1 X179.680 Y66.435 F254.0
G1 X180.298 Y65.091 F254.0
G1 X181.455 Y61.753 F254.0
G1 X182.026 Y58.531 F254.0
G1 X181.657 Y56.902 F254.0
G1 X180.770 Y54.058 F254.0
G1 X178.042 Y49.764 F254.0
G1 X176.947 Y48.742 F254.0
G1 X175.574 Y47.650 F254.0
G1 X174.564 Y47.058 F254.0
G1 X172.140 Y46.011 F254.0
G1 X169.524 Y45.127 F254.0
G1 X166.884 Y44.934 F254.0
G1 X165.719 Y45.171 F254.0
G1 X161.113 Y47.406 F254.0
G1 X160.165 Y48.049 F254.0
G1 X157.100 Y50.398 F254.0
G1 X155.806 Y52.074 F254.0
G1 X154.965 Y53.603 F254.0
G1 X153.806 Y56.380 F254.0
G1 X153.405 Y58.107 F254.0
G1 X153.451 Y60.235 F254.0
G1 X153.888 Y62.008 F254.0
G1 X154.663 Y63.895 F254.0
G1 X155.611 Y65.685 F254.0
G1 X158.144 Y69.089 F254.0
G1 X159.645 Y70.369 F254.0
G1 X161.067 Y71.172 F254.0
G1 X162.784 Y71.968 F254.0
G1 X166.632 Y73.155 F254.0
G1 X170.626 Y72.957 F254.0
G1 X172.529 Y72.319 F254.0
G1 X174.292 Y71.472 F254.0
G1 X176.430 Y70.146 F254.0
G1 X177.743 Y69.163 F254.0
G1 X178.913 Y67.809 F254.0
G1 X179.678 Y66.434 F254.0
G1 X180.296 Y65.090 F254.0
G1 X181.452 Y61.753 F254.0
G1 X182.024 Y58.531 F254.0
G1 X181.655 Y56.903 F254.0
G1 X180.767 Y54.059 F254.0
G1 X178.040 Y49.765 F254.0
G1 X176.946 Y48.744 F254.0
G1 X175.572 Y47.651 F254.0
G1 X174.562 Y47.059 F254.0
G1 X172.139 Y46.013 F254.0
G1 X169.523 Y45.128 F254.0
G1 X166.885 Y44.937 F254.0
G1 X165.720 Y45.173 F254.0
G1 X161.113 Y47.407 F254.0
G1 X160.166 Y48.051 F254.0
G1 X157.100 Y50.400 F254.0
G1 X155.808 Y52.075 F254.0
G1 X154.967 Y53.604 F254.0
G1 X153.808 Y56.380 F254.0
G1 X153.408 Y58.107 F254.0
G1 X153.453 Y60.235 F254.0
G1 X153.891 Y62.008 F254.0
G1 X154.665 Y63.894 F254.0
G1 X155.612 Y65.684 F254.0
G1 X158.145 Y69.088 F254.0
G1 X159.646 Y70.367 F254.0
G1 X161.068 Y71.171 F254.0
G1 X162.785 Y71.967 F254.0
G1 X166.632 Y73.153 F254.0
G1 X170.626 Y72.954 F254.0
G1 X172.528 Y72.317 F254.0
G1 X174.291 Y71.471 F254.0
G1 X176.430 Y70.145 F254.0
G1 X177.742 Y69.162 F254.0
G1 X178.912 Y67.807 F254.0
G1 X179.677 Y66.432 F254.0
G1 X180.294 Y65.088 F254.0
G1 X181.450 Y61.753 F254.0
G1 X182.021 Y58.531 F254.0
G1 X181.653 Y56.904 F254.0
G1 X180.766 Y54.059 F254.0
G1 X178.039 Y49.767 F254.0
G1 X176.944 Y48.745 F254.0
G1 X175.571 Y47.653 F254.0
G1 X174.561 Y47.061 F254.0
G1 X172.138 Y46.014 F254.0
G1 X169.522 Y45.130 F254.0
G1 X166.886 Y44.939 F254.0
G1 X165.721 Y45.176 F254.0
G1 X161.114 Y47.409 F254.0
G1 X160.167 Y48.052 F254.0
G1 X157.101 Y50.402 F254.0
G1 X155.809 Y52.076 F254.0
G1 X154.968 Y53.604 F254.0
G1 X153.809 Y56.381 F254.0
G1 X153.410 Y58.107 F254.0
G1 X153.456 Y60.235 F254.0
G1 X153.893 Y62.008 F254.0
G1 X154.667 Y63.893 F254.0
G1 X155.614 Y65.684 F254.0
G1 X158.147 Y69.087 F254.0
G1 X159.647 Y70.365 F254.0
G1 X161.068 Y71.169 F254.0
G1 X162.785 Y71.965 F254.0
G1 X166.632 Y73.151 F254.0
G1 X170.626 Y72.952 F254.0
G1 X172.527 Y72.316 F254.0
G1 X174.290 Y71.469 F254.0
G1 X176.429 Y70.143 F254.0
G1 X177.740 Y69.160 F254.0
G1 X178.910 Y67.806 F254.0
G1 X179.675 Y66.431 F254.0
G1 X180.293 Y65.087 F254.0
G1 X181.448 Y61.753 F254.0
G1 X182.019 Y58.532 F254.0
G1 X181.651 Y56.904 F254.0
G1 X180.763 Y54.060 F254.0
G1 X178.037 Y49.768 F254.0
G1 X176.943 Y48.747 F254.0
G1 X175.569 Y47.654 F254.0
G1 X174.559 Y47.062 F254.0
G1 X172.138 Y46.016 F254.0
G1 X169.521 Y45.131 F254.0
G1 X166.887 Y44.941 F254.0
G1 X165.722 Y45.178 F254.0
G1 X161.115 Y47.410 F254.0
G1 X160.168 Y48.054 F254.0
G1 X157.102 Y50.403 F254.0
G1 X155.811 Y52.077 F254.0
G1 X154.970 Y53.605 F254.0
G1 X153.811 Y56.382 F254.0
G1 X153.412 Y58.107 F254.0
G1 X153.458 Y60.235 F254.0
G1 X153.895 Y62.008 F254.0
G1 X154.668 Y63.892 F254.0
G1 X155.615 Y65.683 F254.0
G1 X158.148 Y69.086 F254.0
G1 X159.648 Y70.364 F254.0
G1 X161.069 Y71.168 F254.0
G1 X162.786 Y71.964 F254.0
G1 X166.632 Y73.148 F254.0
G1 X170.626 Y72.950 F254.0
G1 X172.527 Y72.314 F254.0
G1 X174.289 Y71.468 F254.0
G1 X176.428 Y70.141 F254.0
G1 X177.739 Y69.159 F254.0
G1 X178.908 Y67.804 F254.0
G1 X179.674 Y66.429 F254.0
G1 X180.291 Y65.085 F254.0
G1 X181.446 Y61.753 F254.0
G1 X182.017 Y58.533 F254.0
G1 X181.649 Y56.905 F254.0
G1 X180.761 Y54.061 F254.0
G1 X178.036 Y49.770 F254.0
G1 X176.941 Y48.748 F254.0
G1 X175.568 Y47.656 F254.0
G1 X174.558 Y47.064 F254.0
G1 X172.137 Y46.017 F254.0
G1 X169.521 Y45.133 F254.0
G1 X166.887 Y44.944 F254.0
G1 X165.722 Y45.180 F254.0
G1 X161.116 Y47.412 F254.0
G1 X160.169 Y48.055 F254.0
G1 X157.103 Y50.405 F254.0
G1 X155.812 Y52.077 F254.0
G1 X154.971 Y53.606 F254.0
G1 X153.812 Y56.383 F254.0
G1 X153.415 Y58.107 F254.0
G1 X153.460 Y60.235 F254.0
G1 X153.898 Y62.008 F254.0
G1 X154.670 Y63.891 F254.0
G1 X155.617 Y65.682 F254.0
G1 X158.150 Y69.086 F254.0
G1 X159.648 Y70.362 F254.0
G1 X161.070 Y71.166 F254.0
G1 X162.787 Y71.962 F254.0
G1 X166.632 Y73.146 F254.0
G1 X170.626 Y72.947 F254.0
G1 X172.526 Y72.313 F254.0
G1 X174.289 Y71.466 F254.0
G1 X176.427 Y70.140 F254.0
G1 X177.737 Y69.157 F254.0
G1 X178.907 Y67.803 F254.0
G1 X179.672 Y66.428 F254.0
G1 X180.290 Y65.084 F254.0
G1 X181.443 Y61.753 F254.0
G1 X182.014 Y58.534 F254.0
G1 X181.646 Y56.906 F254.0
G1 X180.759 Y54.062 F254.0
G1 X178.034 Y49.771 F254.0
G1 X176.940 Y48.750 F254.0
G1 X175.566 Y47.658 F254.0
G1 X174.556 Y47.065 F254.0
G1 X172.136 Y46.019 F254.0
G1 X169.520 Y45.134 F254.0
G1 X166.888 Y44.946 F254.0
G1 X165.723 Y45.183 F254.0
G1 X161.117 Y47.413 F254.0
G1 X160.169 Y48.057 F254.0
G1 X157.104 Y50.406 F254.0
G1 X155.814 Y52.078 F254.0
G1 X154.973 Y53.607 F254.0
G1 X153.814 Y56.383 F254.0
G1 X153.417 Y58.107 F254.0
G1 X153.463 Y60.235 F254.0
G1 X153.900 Y62.008 F254.0
G1 X154.671 Y63.891 F254.0
G1 X155.618 Y65.681 F254.0
G1 X158.152 Y69.085 F254.0
G1 X159.649 Y70.361 F254.0
G1 X161.071 Y71.165 F254.0
G1 X162.788 Y71.961 F254.0
G1 X166.632 Y73.144 F254.0
G1 X170.626 Y72.945 F254.0
G1 X172.525 Y72.311 F254.0
G1 X174.288 Y71.465 F254.0
G1 X176.426 Y70.138 F254.0
G1 X177.736 Y69.155 F254.0
G1 X178.905 Y67.801 F254.0
G1 X179.670 Y66.426 F254.0
G1 X180.288 Y65.082 F254.0
G1 X181.441 Y61.753 F254.0
G1 X182.012 Y58.534 F254.0
G1 X181.644 Y56.907 F254.0
G1 X180.756 Y54.063 F254.0
G1 X178.033 Y49.773 F254.0
G1 X176.938 Y48.751 F254.0
G1 X175.564 Y47.659 F254.0
G1 X174.554 Y47.067 F254.0
G1 X172.135 Y46.020 F254.0
G1 X169.519 Y45.136 F254.0
G1 X166.889 Y44.948 F254.0
G1 X165.724 Y45.185 F254.0
G1 X161.117 Y47.415 F254.0
G1 X160.170 Y48.058 F254.0
G1 X157.104 Y50.408 F254.0
G1 X155.815 Y52.079 F254.0
G1 X154.974 Y53.608 F254.0
G1 X153.815 Y56.384 F254.0
G1 X153.419 Y58.107 F254.0
G1 X153.465 Y60.235 F254.0
G1 X153.902 Y62.008 F254.0
G1 X154.673 Y63.890 F254.0
G1 X155.620 Y65.680 F254.0
G1 X158.153 Y69.084 F254.0
G1 X159.650 Y70.359 F254.0
G1 X161.072 Y71.163 F254.0
G1 X162.789 Y71.959 F254.0
G1 X166.632 Y73.141 F254.0
G1 X170.626 Y72.943 F254.0
G1 X172.524 Y72.310 F254.0
G1 X174.287 Y71.463 F254.0
G1 X176.426 Y70.137 F254.0
G1 X177.734 Y69.154 F254.0
G1 X178.904 Y67.800 F254.0
G1 X179.669 Y66.425 F254.0
G1 X180.287 Y65.081 F254.0
G1 X181.439 Y61.753 F254.0
G1 X182.010 Y58.535 F254.0
G1 X181.642 Y56.907 F254.0
G1 X180.754 Y54.063 F254.0
G1 X178.031 Y49.774 F254.0
G1 X176.936 Y48.753 F254.0
G1 X175.563 Y47.661 F254.0
G1 X174.553 Y47.068 F254.0
G1 X172.134 Y46.022 F254.0
G1 X169.518 Y45.138 F254.0
G1 X166.890 Y44.951 F254.0
G1 X165.725 Y45.187 F254.0
G1 X161.118 Y47.416 F254.0
G1 X160.171 Y48.060 F254.0
G1 X157.105 Y50.409 F254.0
G1 X155.817 Y52.080 F254.0
G1 X154.976 Y53.608 F254.0
G1 X153.817 Y56.385 F254.0
G1 X153.422 Y58.107 F254.0
G1 X153.467 Y60.235 F254.0
G1 X153.905 Y62.008 F254.0
G1 X154.674 Y63.889 F254.0
G1 X155.622 Y65.680 F254.0
G1 X158.155 Y69.083 F254.0
G1 X159.651 Y70.358 F254.0
G1 X161.072 Y71.162 F254.0
G1 X162.789 Y71.958 F254.0
G1 X166.632 Y73.139 F254.0
G1 X170.626 Y72.941 F254.0
G1 X172.524 Y72.308 F254.0
G1 X174.286 Y71.462 F254.0
G1 X176.425 Y70.135 F254.0
G1 X177.733 Y69.152 F254.0
G1 X178.902 Y67.798 F254.0
G1 X179.667 Y66.423 F254.0
G1 X180.285 Y65.079 F254.0
G1 X181.436 Y61.753 F254.0
G1 X182.007 Y58.536 F254.0
G1 X181.639 Y56.908 F254.0
G1 X180.752 Y54.064 F254.0
G1 X178.029 Y49.776 F254.0
G1 X176.935 Y48.754 F254.0
G1 X175.561 Y47.662 F254.0
G1 X174.551 Y47.070 F254.0
G1 X172.134 Y46.024 F254.0
G1 X169.518 Y45.139 F254.0
G1 X166.891 Y44.953 F254.0
G1 X165.726 Y45.189 F254.0
G1 X161.119 Y47.418 F254.0
G1 X160.172 Y48.061 F254.0
G1 X157.106 Y50.411 F254.0
G1 X155.818 Y52.081 F254.0
G1 X154.977 Y53.609 F254.0
G1 X153.819 Y56.386 F254.0
G1 X153.424 Y58.107 F254.0
G1 X153.470 Y60.235 F254.0
G1 X153.907 Y62.008 F254.0
G1 X154.676 Y63.888 F254.0
G1 X155.623 Y65.679 F254.0
G1 X158.156 Y69.083 F254.0
G1 X159.651 Y70.356 F254.0
G1 X161.073 Y71.160 F254.0
G1 X162.790 Y71.956 F254.0
G1 X166.632 Y73.137 F254.0
G1 X170.626 Y72.938 F254.0
G1 X172.523 Y72.306 F254.0
G1 X174.285 Y71.460 F254.0
G1 X176.424 Y70.134 F254.0
G1 X177.731 Y69.151 F254.0
G1 X178.901 Y67.797 F254.0
G1 X179.666 Y66.422 F254.0
G1 X180.284 Y65.077 F254.0
G1 X181.434 Y61.753 F254.0
G1 X182.005 Y58.537 F254.0
G1 X181.637 Y56.909 F254.0
G1 X180.749 Y54.065 F254.0
G1 X178.028 Y49.778 F254.0
G1 X176.933 Y48.756 F254.0
G1 X175.560 Y47.664 F254.0
G1 X174.550 Y47.072 F254.0
G1 X172.133 Y46.025 F254.0
G1 X169.517 Y45.141 F254.0
G1 X166.891 Y44.955 F254.0
G1 X165.726 Y45.192 F254.0
G1 X161.120 Y47.420 F254.0
G1 X160.172 Y48.063 F254.0
G1 X157.107 Y50.412 F254.0
G1 X155.820 Y52.081 F254.0
G1 X154.979 Y53.610 F254.0
G1 X153.820 Y56.386 F254.0
G1 X153.426 Y58.107 F254.0
G1 X153.472 Y60.235 F254.0
G1 X153.909 Y62.008 F254.0
G1 X154.677 Y63.888 F254.0
G1 X155.625 Y65.678 F254.0
G1 X158.158 Y69.082 F254.0
G1 X159.652 Y70.355 F254.0
G1 X161.074 Y71.158 F254.0
G1 X162.791 Y71.955 F254.0
G1 X166.632 Y73.134 F254.0
G1 X170.626 Y72.936 F254.0
G1 X172.522 Y72.305 F254.0
G1 X174.285 Y71.458 F254.0
G1 X176.423 Y70.132 F254.0
G1 X177.729 Y69.149 F254.0
G1 X178.899 Y67.795 F254.0
G1 X179.664 Y66.420 F254.0
G1 X180.282 Y65.076 F254.0
G1 X181.432 Y61.753 F254.0
G1 X182.003 Y58.538 F254.0
G1 X181.635 Y56.910 F254.0
G1 X180.747 Y54.066 F254.0
G1 X178.026 Y49.779 F254.0
G1 X176.932 Y48.757 F254.0
G1 X175.558 Y47.665 F254.0
G1 X174.548 Y47.073 F254.0
G1 X172.132 Y46.027 F254.0
G1 X169.516 Y45.142 F254.0
G1 X166.892 Y44.958 F254.0
G1 X165.727 Y45.194 F254.0
G1 X161.120 Y47.421 F254.0
G1 X160.173 Y48.065 F254.0
G1 X157.107 Y50.414 F254.0
G1 X155.821 Y52.082 F254.0
G1 X154.980 Y53.611 F254.0
G1 X153.822 Y56.387 F254.0
G1 X153.429 Y58.107 F254.0
G1 X153.474 Y60.235 F254.0
G1 X153.912 Y62.008 F254.0
G1 X154.679 Y63.887 F254.0
G1 X155.626 Y65.677 F254.0
G1 X158.159 Y69.081 F254.0
G1 X159.653 Y70.353 F254.0
G1 X161.075 Y71.157 F254.0
G1 X162.792 Y71.953 F254.0
G1 X166.632 Y73.132 F254.0
G1 X170.626 Y72.934 F254.0
G1 X172.521 Y72.303 F254.0
G1 X174.284 Y71.457 F254.0
G1 X176.423 Y70.131 F254.0
G1 X177.728 Y69.148 F254.0
G1 X178.898 Y67.794 F254.0
G1 X179.663 Y66.418 F254.0
G1 X180.280 Y65.074 F254.0
G1 X181.429 Y61.753 F254.0
G1 X182.001 Y58.538 F254.0
G1 X181.632 Y56.910 F254.0
G1 X180.745 Y54.066 F254.0
G1 X178.025 Y49.781 F254.0
G1 X176.930 Y48.759 F254.0
G1 X175.557 Y47.667 F254.0
G1 X174.547 Y47.075 F254.0
G1 X172.131 Y46.028 F254.0
G1 X169.515 Y45.144 F254.0
G1 X166.893 Y44.960 F254.0
G1 X165.728 Y45.196 F254.0
G1 X161.121 Y47.423 F254.0
G1 X160.174 Y48.066 F254.0
G1 X157.108 Y50.416 F254.0
G1 X155.823 Y52.083 F254.0
G1 X154.982 Y53.611 F254.0
G1 X153.823 Y56.388 F254.0
G1 X153.431 Y58.107 F254.0
G1 X153.477 Y60.235 F254.0
G1 X153.914 Y62.008 F254.0
G1 X154.680 Y63.886 F254.0
G1 X155.628 Y65.677 F254.0
G1 X158.161 Y69.080 F254.0
G1 X159.654 Y70.352 F254.0
G1 X161.075 Y71.155 F254.0
G1 X162.792 Y71.951 F254.0
G1 X166.632 Y73.130 F254.0
G1 X170.626 Y72.931 F254.0
G1 X172.520 Y72.302 F254.0
G1 X174.283 Y71.455 F254.0
G1 X176.422 Y70.129 F254.0
G1 X177.726 Y69.146 F254.0
G1 X178.896 Y67.792 F254.0
G1 X179.661 Y66.417 F254.0
G1 X180.279 Y65.073 F254.0
G1 X181.427 Y61.753 F254.0
G1 X181.998 Y58.538 F254.0
G1 X181.631 Y56.911 F254.0
G1 X180.743 Y54.067 F254.0
G1 X178.023 Y49.782 F254.0
G1 X176.929 Y48.761 F254.0
G1 X175.555 Y47.668 F254.0
G1 X174.545 Y47.076 F254.0
G1 X172.131 Y46.030 F254.0
G1 X169.514 Y45.145 F254.0
G1 X166.894 Y44.962 F254.0
G1 X165.729 Y45.199 F254.0
G1 X161.122 Y47.424 F254.0
G1 X160.175 Y48.068 F254.0
G1 X157.109 Y50.417 F254.0
G1 X155.825 Y52.084 F254.0
G1 X154.984 Y53.612 F254.0
G1 X153.825 Y56.389 F254.0
G1 X153.433 Y58.107 F254.0
G1 X153.479 Y60.235 F254.0
G1 X153.916 Y62.008 F254.0
G1 X154.682 Y63.885 F254.0
G1 X155.629 Y65.676 F254.0
G1 X158.162 Y69.080 F254.0
G1 X159.655 Y70.350 F254.0
G1 X161.076 Y71.154 F254.0
G1 X162.793 Y71.950 F254.0
G1 X166.632 Y73.127 F254.0
G1 X170.626 Y72.929 F254.0
G1 X172.520 Y72.300 F254.0
G1 X174.282 Y71.454 F254.0
G1 X176.421 Y70.128 F254.0
G1 X177.725 Y69.145 F254.0
G1 X178.895 Y67.790 F254.0
G1 X179.660 Y66.415 F254.0
G1 X180.277 Y65.071 F254.0
G1 X181.425 Y61.753 F254.0
G1 X181.996 Y58.539 F254.0
G1 X181.628 Y56.912 F254.0
G1 X180.741 Y54.068 F254.0
G1 X178.022 Y49.784 F254.0
G1 X176.927 Y48.762 F254.0
G1 X175.554 Y47.670 F254.0
G1 X174.544 Y47.078 F254.0
G1 X172.130 Y46.031 F254.0
G1 X169.514 Y45.147 F254.0
G1 X166.894 Y44.965 F254.0
G1 X165.729 Y45.201 F254.0
G1 X161.123 Y47.426 F254.0
G1 X160.175 Y48.069 F254.0
G1 X157.110 Y50.419 F254.0
G1 X155.826 Y52.084 F254.0
G1 X154.985 Y53.613 F254.0
G1 X153.826 Y56.390 F254.0
G1 X153.436 Y58.107 F254.0
G1 X153.481 Y60.235 F254.0
G1 X153.919 Y62.008 F254.0
G1 X154.684 Y63.884 F254.0
G1 X155.631 Y65.675 F254.0
G1 X158.164 Y69.079 F254.0
G1 X159.655 Y70.348 F254.0
G1 X161.077 Y71.152 F254.0
G1 X162.794 Y71.948 F254.0
G1 X166.632 Y73.125 F254.0
G1 X170.626 Y72.927 F254.0
G1 X172.519 Y72.299 F254.0
G1 X174.282 Y71.452 F254.0
G1 X176.420 Y70.126 F254.0
G1 X177.723 Y69.143 F254.0
G1 X178.893 Y67.789 F254.0
G1 X179.658 Y66.414 F254.0
G1 X180.276 Y65.070 F254.0
G1 X181.422 Y61.753 F254.0
G1 X181.994 Y58.540 F254.0
G1 X181.626 Y56.913 F254.0
G1 X180.739 Y54.069 F254.0
G1 X178.020 Y49.785 F254.0
G1 X176.926 Y48.764 F254.0
G1 X175.552 Y47.672 F254.0
G1 X174.542 Y47.079 F254.0
G1 X172.129 Y46.033 F254.0
G1 X169.513 Y45.148 F254.0
G1 X166.895 Y44.967 F254.0
G1 X165.730 Y45.203 F254.0
G1 X161.123 Y47.427 F254.0
G1 X160.176 Y48.071 F254.0
G1 X157.111 Y50.420 F254.0
G1 X155.828 Y52.085 F254.0
G1 X154.987 Y53.614 F254.0
G1 X153.828 Y56.390 F254.0
G1 X153.438 Y58.107 F254.0
G1 X153.484 Y60.235 F254.0
G1 X153.921 Y62.008 F254.0
G1 X154.685 Y63.884 F254.0
G1 X155.632 Y65.674 F254.0
G1 X158.166 Y69.078 F254.0
G1 X159.656 Y70.347 F254.0
G1 X161.078 Y71.151 F254.0
G1 X162.795 Y71.947 F254.0
G1 X166.632 Y73.123 F254.0
G1 X170.626 Y72.924 F254.0
G1 X172.518 Y72.297 F254.0
G1 X174.281 Y71.451 F254.0
G1 X176.419 Y70.124 F254.0
G1 X177.722 Y69.142 F254.0
G1 X178.891 Y67.787 F254.0
G1 X179.656 Y66.412 F254.0
G1 X180.274 Y65.068 F254.0
G1 X181.420 Y61.753 F254.0
G1 X181.991 Y58.541 F254.0
G1 X181.624 Y56.914 F254.0
G1 X180.736 Y54.070 F254.0
G1 X178.019 Y49.787 F254.0
G1 X176.924 Y48.765 F254.0
G1 X175.551 Y47.673 F254.0
G1 X174.541 Y47.081 F254.0
G1 X172.128 Y46.034 F254.0
G1 X169.512 Y45.150 F254.0
G1 X166.896 Y44.969 F254.0
G1 X165.731 Y45.206 F254.0
G1 X161.124 Y47.429 F254.0
G1 X160.177 Y48.072 F254.0
G1 X157.111 Y50.422 F254.0
G1 X155.829 Y52.086 F254.0
G1 X154.988 Y53.615 F254.0
G1 X153.829 Y56.391 F254.0
G1 X153.440 Y58.107 F254.0
G1 X153.486 Y60.235 F254.0
G1 X153.923 Y62.008 F254.0
G1 X154.687 Y63.883 F254.0
G1 X155.634 Y65.674 F254.0
G1 X158.167 Y69.077 F254.0
G1 X159.657 Y70.345 F254.0
G1 X161.079 Y71.149 F254.0
G1 X162.795 Y71.945 F254.0
G1 X166.632 Y73.120 F254.0
G1 X170.626 Y72.922 F254.0
G1 X172.517 Y72.296 F254.0
G1 X174.280 Y71.449 F254.0
G1 X176.419 Y70.123 F254.0
G1 X177.720 Y69.140 F254.0
G1 X178.890 Y67.786 F254.0
G1 X179.655 Y66.411 F254.0
G1 X180.273 Y65.067 F254.0
G1 X181.418 Y61.753 F254.0
G1 X181.989 Y58.541 F254.0
G1 X181.621 Y56.914 F254.0
G1 X180.734 Y54.070 F254.0
G1 X178.017 Y49.788 F254.0
G1 X176.923 Y48.767 F254.0
G1 X175.549 Y47.675 F254.0
G1 X174.539 Y47.082 F254.0
G1 X172.127 Y46.036 F254.0
G1 X169.511 Y45.152 F254.0
G1 X166.897 Y44.972 F254.0
G1 X165.732 Y45.208 F254.0
G1 X161.125 Y47.430 F254.0
G1 X160.178 Y48.074 F254.0
G1 X157.112 Y50.423 F254.0
G1 X155.831 Y52.087 F254.0
G1 X154.990 Y53.615 F254.0
G1 X153.831 Y56.392 F254.0
G1 X153.443 Y58.107 F254.0
G1 X153.488 Y60.235 F254.0
G1 X153.925 Y62.008 F254.0
G1 X154.688 Y63.882 F254.0
G1 X155.635 Y65.673 F254.0
G1 X158.169 Y69.076 F254.0
G1 X159.658 Y70.344 F254.0
G1 X161.079 Y71.148 F254.0
G1 X162.796 Y71.944 F254.0
G1 X166.632 Y73.118 F254.0
G1 X170.626 Y72.920 F254.0
G1 X172.517 Y72.294 F254.0
G1 X174.279 Y71.448 F254.0
G1 X176.418 Y70.121 F254.0
G1 X177.719 Y69.138 F254.0
G1 X178.888 Y67.784 F254.0
G1 X179.653 Y66.409 F254.0
G1 X180.271 Y65.065 F254.0
G1 X181.415 Y61.753 F254.0
G1 X181.987 Y58.542 F254.0
G1 X181.619 Y56.915 F254.0
G1 X180.732 Y54.071 F254.0
G1 X178.015 Y49.790 F254.0
G1 X176.921 Y48.768 F254.0
G1 X175.547 Y47.676 F254.0
G1 X174.537 Y47.084 F254.0
G1 X172.127 Y46.037 F254.0
G1 X169.511 Y45.153 F254.0
G1 X166.898 Y44.974 F254.0
G1 X165.733 Y45.210 F254.0
G1 X161.126 Y47.432 F254.0
G1 X160.179 Y48.075 F254.0
G1 X157.113 Y50.425 F254.0
G1 X155.832 Y52.088 F254.0
G1 X154.991 Y53.616 F254.0
G1 X153.832 Y56.393 F254.0
G1 X153.445 Y58.107 F254.0
G1 X153.491 Y60.235 F254.0
G1 X153.928 Y62.008 F254.0
G1 X154.690 Y63.881 F254.0
G1 X155.637 Y65.672 F254.0
G1 X158.170 Y69.076 F254.0
G1 X159.658 Y70.342 F254.0
G1 X161.080 Y71.146 F254.0
G1 X162.797 Y71.942 F254.0
G1 X166.632 Y73.116 F254.0
G1 X170.626 Y72.917 F254.0
G1 X172.516 Y72.292 F254.0
G1 X174.279 Y71.446 F254.0
G1 X176.417 Y70.120 F254.0
G1 X177.717 Y69.137 F254.0
G1 X178.887 Y67.783 F254.0
G1 X179.652 Y66.408 F254.0
G1 X180.270 Y65.063 F254.0
G1 X181.413 Y61.753 F254.0
G1 X181.984 Y58.543 F254.0
G1 X181.617 Y56.916 F254.0
G1 X180.729 Y54.072 F254.0
G1 X178.014 Y49.792 F254.0
G1 X176.919 Y48.770 F254.0
G1 X175.546 Y47.678 F254.0
G1 X174.536 Y47.085 F254.0
G1 X172.126 Y46.039 F254.0
So I copied your file to mach3 and ran it. It just goes around the same circle and only goes downward the first time. I wonder if you have multiple copies of the circle on top of each other? I think 40 lines are one circle and then it repeats itself, but the numbers aren’t quite exactly the same for each pass.
You might want to try another Cam program and see if you get different results. If you saved it as a DXF format, you could try CamBam. That’s what I use.
Can you share the Easel project?
File–>Share–>Share with Link–>Save
Well, I dont, I’m just using sketchup. I will try CamBam.
Thanks
The project you shared, its huge for a 30deg V-bit is specified with a depth = 0.1mm.
Simply wrong tool for the job.
- How wide is a 30deg V-bit cutting when its only engaging 0.1mm of material?
- How small is the stepover when its set to 40%? (actual width)
Using a V-bit for the size of this PCB as shown in Easel is ludicrous
With a feed rate of 254mm/min it will take days…as you have found out.
If the PCB size and shape are correct, try specifying a 3mm straight bit and bump feed rate to 750mm/min, check simulated time difference. There isnt anything in the design that require the fidelity of a V-bit.
Thanks Haldor for the feedback!
I will keep in mind.
