…Hi I have created a NC File with Fusion360. Having a problem importing into Easel. 1st error says simulation file, next tried autocad dump, wrong syntax .
Help
At the bottom of the toolbar is a button to import Gcode. You need to use a GRBL post processor when you generate the Gcode from the CAM software.
I am still unable to inport gcode I have tried to instal post processer with no success
If it is only a 2d file, you could export it as a DXF file format and load that into Easel.
Take a look at this to see if it helps.
Importing Gcode from Fusion 360 into Easel – Inventables (zendesk.com)
Installing Fusion 360 Post Processor – Inventables (zendesk.com)
