Gcode on Mach3 to slow
Hello I hope to receive your help.
I created on Easel an engraving on a wooden tablet.
The simulation states 10 minutes or less.
I create the gcode and export it to my CNC on Mach3.
Duration of the job 1 hour and 40 minutes.
I can understand twice as long, but 10 times as long, and a lot.
Do you have this problem do you have any ideas on how I can solve it?
There are a number of factors that Easel doesn’t know about your CNC and as a result it often uses the X-Carve defaults for these calculations.
Also note that although the Easel gcode often works for Mach3 it isn’t correctly designed for Mach and as a result you may have even worse carve times… I’d check out a software that actually uses a Mach3 post processor for better results. Like Fusion360, or Vectric, or Carveco… Carveco CAD/CAM Software - 90 Days Free (Maker) – His N Hers Handcrafted
