I can’t seem to get the finish pass to generate a tool path. After I click generate tool path it will start to process then I get a error saying oh snap something went wrong and that I ran out of memory. Any one know the fix on that?
I received nothing but errors when using bits below 2mm diameter so I stopped trying to use my tapered ball bits altogether. BUT the toolpaths do run on the users PC and if you have low RAM or a slow processor that could extend how long it takes to calculate the paths as well.
Thanks Seth that’s what it is. Trying to use to small of a bit.
Thanks for the feedback about bit diameter - I will send that along to the team
