Hey there! I have been running my JTech 7w laser on my X-Carve with X-Controller for about 3 weeks now and I was doing a test burn on a piece of cedar and I began to notice some vertical lines in the solid filled squares.
I looked back at some previous test pieces I have done and I can see it faintly on those also. (I think that the cedar is the softest material I have tested on and that is why it is more prominent.) I am not sure what may be causing this.
What I have tried.
- Cleaning all rails, bearing, wheels, etc.
- Checked that all V-Wheels are adjust appropriately.
- Check belt tension and adjusted accordingly. (Not to tight, not to loose as far as I understand)
I found a similar thread here but was closed.
Here are my GRBL settings if needed, and if I can provide anymore information, I would be more than happy!
$0=10
$1=255
$2=0
$3=3
$4=0
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=25.000
$25=750.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=40.000
$101=40.000
$102=188.976
$110=8000.000
$111=8000.000
$112=500.000
$120=500.000
$121=500.000
$122=50.000
$130=750.000
$131=750.000
$132=100.000
