Ghost Cuts
When ever I use my Probe to get my Z set my bit does 5 Ghost passes before making the actual cut. Is there a way to figure out how to stop this? It’s causing my projects to take way longer than they should
Thanks in advance for all help,
Cody
Is the thickness of your probe set properly? Do you have the Inventables touch probe or one from somewhere else (which might be thinner)?
I am using the Inventables probe that came with my machine
What program are you using to setup and send your carves to the machine with?
Is your probe setup with a macro or easel?
More information is needed here…
I use easel to do my cuts
Ok. In the machine inspector, advanced settings, make sure that the probe thickness is set correctly. Double check it with a digital caliper, and change it if there is a discrepancy.
