Hello,
I had GRBL Offline Controller board. When I received the controller, it is had 3 files to test the machine. The machine worked well (3018). But, when I load files to the controller from Easel, the controller did not start the machine. Why??
I had the exact same problem.
So far my solution was to make sure easel has the machine set for spindle control to automatic, also I have to run the.nc file through the candle program and save from that onto my offline controller. I’m still new but so far that has worked.
Good luck!
Hi.i know its an old post . I’ve been having these problems did you create design on easle then import the files to candle then export them like that from candle?
