GRBL V1.1 master release
For those who want to experiment with 1.1e here is a version set up for the X-carve 1000.
Only changes from the master on github are:
#define HOMING_FORCE_SET_ORIGIN
#define DEFAULTS_X_CARVE_1000MM
Homing_Force_Set_Origin makes the Work Position positive space and the other should be obvious.
Changed report.c to be able to identify this version with the $I command:
([VER:1.1e.20161208 Xcarve 1000 :])
Xcarve_1000.hex (83.8 KB)
@LarryM – I was about to ask you for a link or something on how to download and compile, then I saw the attached hex file. Many thanks!!
I’m trying to figure out what this means exactly… Homing_force_set_origin… Does that mean, if I set my Z Axis zero to the top of the top plane of my stock, It will carve everything below, or am I mis-understanding what that means…
Thanks!
Traditionally, in CNC work, machine space is in the negative quadrant. Just a fancy way to say all X and Y co-ordinates are negative.
The Homing_force_set_origin compile time option just moves the co-ordinates into positive space. All X and Y values are positive.
It’s just more intuitive for me to work with positive numbers, so when I build a version of grbl, most of the time I use this compile time option to move machine co-ordinates into positive space.
I did a really nice carve yesterday w/o issues so it works great.
