gShield not level
Everything works on my X-Carve, but the gShield sits lower on one end and doesn’t sit level with the enclosure. It’s annoying me. Has anyone else had this issue?
I haven’t had that issue, but it is a problem waiting to happen. If the gShield is on an angle with the Arduino then it is not plugged in properly.
Since everything is working you probably have all the pins in the right places they are just not plugged in all the way.
After I got mine in the case I put two small plastic spacers in diagonal corners to keep the gShield from rising off the Arduino and then installed the case enclosure with the fan.
