Probably a simple answer … how do I cut a full circle in half once selected from the shape selection, has me beat ?
create a circle using the circle icon
click on edit point
delete bottom point
click on each side point and pull the bottom tab around until you see a red line
You can also make a square and set to zero depth and place it on top of your circle. The edge of your square will be set at the diameter
