24x29inch mdf, flat black spray paint. 60degree vbit 3-4 hours.
One really important lesson learned. Make your background black so you can place all the dots on the subject. This one has 8500 dots on it.
For anyone interested in using Halftoner to do this, Easel isn’t currently compatible with the GCode halftoner outputs. I’m working with @JasonDorie on a patch to address that. If you want instructions on editing the GCode now, shoot me a message. I’ll do a post soon on that, and have a new release on my forked copy.
Final
Source
Preview
Generator settings
Toolpath settings
The GCode halftoner 1.6 generates was not fully compatible with Easel at the time of writing.
You are correct that the GCode that Halftoner V1.6 creates needs to be modified to make it compatible with Easel.
- Remove all of the Line number N### commands from each line.
is the symbol which means a number 0-9 in the U.S.
Change all G00 to G0
Change all G01 to G1
Change the first line containing
G00 G20 G17 G90 G40 G49 G80
to
G0 G20 G17 G90 -
Remove second line T1 M06
Change the second to last line from M05 to M5
