I’ve upgraded from a 500x500 xcarve to a 1000x1000 xcarve THEN I updated to the one piece y axis. Needless to say… I have pretty good stock of leftover makerslide.(with about four leftover nema 17s)
Seems like a 3d printer would be the way to go
Wondering if anyone has use their leftovers to make a 3d printer.
Looks like there is an ORDbot hadron that seems to work… anyone done this one? Got a build log?
Any others based off of makerslide?
There’s a fully 3d-printed 3d printer on Thingiverse, perhaps you could sub the printed slides (at least I think they are) with your surplus, then use shapeways, or a friend to print the other parts for you…
I’ve had an Ord Hadron for a bit over 3 years and it’s a very good printer.
I’ve made a few modifications such as fitting ACME threaded rods for the Z axis (original was 8mm threaded rod) and ‘anti wobble’ nuts to remove any Z-axis side to side movement. Lots of mods detailed on thingiverse.
The CAD drawings are available on the buildlog.net website for cutting out on your X-Carve.
Did a little more research… now I’m leaning towards a Delta design due to the fact that I have three 1000mm makerslide rails. and I could use the Xcarve to make bases.
here’s another that uses linear bearings but could probably be modded to use the maker slide. Bonus that the creator uses cnc’d parts. https://www.youtube.com/watch?v=ua2QKV8V234
