I am working on some Christmas gifts and thought about signs in plastic HDME. I am carving them but don’t get a nice clean edge. I have changed the bit to a newer one thinking it was that.
I have attached pictures for u to see.
you are in need of some speed, try increasing your feed rate by 25% and decrease spindle speed if possible?
feed = 72 in/min
plunge = 24 in/min
depth = .032 in
What would you suggest?
Thanks,
Todd
all machines have different capabilities, I’m not a mind reader (so what machine do you have)
feed = 100 in/min
plunge = 40 in/min
depth =? in
End Mill Single Flute Spiral Router Bit Milling Cutter Upcut Cutting Engraving Single Edged Acrylic Plastic MDF
sorry, Using a 60 degree bit on an easel Milwaukee router - i have it on the slowest speed setting 1
great job!!!
