I was in the middle of a cut when the DEWALT DWP611 router spindle stopped spinning. I have power to the LEDs and no breakers are tripped. Is there an internal heat overload? XCARVE 1000mm and is less than 3 months old.
look at the brushes in your motor…
thanks i will check those… how long do the normally last?
it is the brushes… only a 1/2 to a 1/4 inch left. thanks for you help. seems like this is going to be a stock item to have on hand. I noticed Dewalt has a brushless cordless router… too bad they don’t have a corded one.
