We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youâve provided to them or that theyâve collected from your use of their services. Learn more.
Thank Phil. I was actually wondering how you removed so much material using Fengrave? I would like to avoid cutting out the large areas of the horns with a v-bit.
Ex. The outer edges of the horn pockets will be v-carved and the bottom will be flat, but Iâd like to hog away most of the inner material with a larger bit to save on cutting time. Would I use Fengrave to straight bit cut, then clean up with a smaller straight bit, then v-bit clean up and that would just do most of the v-bit cutting? Or v-bit cut, clean up with my larger straight bit, and then v-bit clean up?
I just donât understand how to stack the processes⌠Thanks for all your help guys.
