Help making Font style into svg
I’ve searched and searched for letters written a specific way and can’t find. Are there any Guru’s out there that can create what i want. i’m only asking for 3 letters! My buddy is retiring and i’m trying to make a sign with those 3 letters, with the little end thingys on all 3(official term) and then be able to stack them so they touch. Sign is going to be 20 x 20 circle, and the letters are to be centered. Help me, Obi-wan Kenobi, You’re my only hope!!
Try searching Google fonts. They are all free to use.
The part at the end of the letter is called the “serif”. If a font does not have that part, it is called “sans serif” meaning “without stroke”.
If you use the search above, it will get you all of the fonts that have a serif and are thin like lines rather than thick letters with infill.
The example here is a font called “Josefin Slab”
Thanks for the input. I guess i should have been more specific. I want the letters to be written “like i supplied”, but a little thicker, but i need them as a SVG. i don’t know how to make it.
letter3
Here it is as an SVG with thickness. It might need some work in something like inkscape.
Here it is as a project in Easel.
https://easel.inventables.com/projects/7rtxOmjth2UaWo7aq3AD6A
