What is causing my x axis to skip?
That video shows the Y skipping and likely because of the chips covering the path that the vwheels are riding on…
Also I see the front bottom wheel rotating and not the back bottom, this means that the eccentric nuts are probably not adjusted properly.
clean off the rails, adjust the eccentric nuts, and re-try.
If it is still failing , a wider angle showing both sides might help troubleshooting.
