Please, is there anyone who can help me with how to put
various pictures of my basic image
Kristian
http://easel.inventables.com/projects/Z6Z03YIFKyCOtWSPJOAHCA
Kristian
How are creating your graphic? in Easel or inkscape?
I inported the pattern from a PDF file to inkscape and then save as SVG
How did you do that ?
I have not combine it before
In inkscape use the “Break Apart” or “Ungroup” to ensure all elements are separate
I did that but nothing happen
I still got the same results
I did ungroup but got the same results
I can´t find where to break apart
Please show me
I think I found the Break apart but it is in Swedish
Should I break apart in inkscape ?
Or someplace else
In Inkscape, select all and then break apart
Sorry I couldn`t break it apart in inkscap
Can you post the SVG here, just drag and drop it in a reply
yes sir
hang on
Sorry I couldn´t drag and drop it
I think I´m the most idiot here
Puh…
How did you that ?
Open you SVG in inkscape
Select all [control a]
with all selected ungroup
now click on empty part of screen
click on graphic and drag, you should see 2 parts
1 of them is the image file
Delete the image
now select the graphic and break apart
