Could any one tell me what might be causing this issue?
Thanks.
Rusty
June 25, 2016, 4:13am
2
Looks like some belt slippage, or loose v-wheel. Also check that you pulleys are tight, the grub screw like to back out from time to time.
And that your POTs are tuned to the right setting. (Potentiometers)
Check out these threads for a troubleshooting guide and videos to make adjustments to various parts:
Positioning Errors
One of the most asked about troubleshooting problems with a new X-carve is positioning errors. Almost all positioning errors are corrected by adjusting the various parts of the machine. Very few of the problems are actually due to failing components. The X-carve is a very flexible machine and so one answer cannot fit all situations. Each person will use their machine in a different way which makes it difficult to precisely quantify each adjustment.
Positioning errors are alm…
There are a lot of repeated questions and answers on here, and some good videos that explain everything. I’ve got 2 maintenance and one X-axis stiffening video that I made that may help with some X-Carve maintenance and troubleshooting.
Since a picture is worth a thousand words, videos have got to be worth a few more. If you’ve got a video, or like a video someone else has, put it up on here. Let’s make a collection that will be easy to reference for various X-Carve users!
Thanks for all the help, tightened up all the belts and checked the v wheels and it seems to have helped a lot.
Don’t think it’s spot on yet but getting closer.
Thanks once again.
