Hello,
I am looking at adapting the X-Carve into a test fixture but I can use some electrical help. In addition to the four step motors I also need to control one REV NEO Brushless Motor using the Spark Max motor controller.
Spark Max Motor Controller
Spark Max Motor Controller Manual
The motor controller works with a pwm signal and the X Controller seems to output a pwm signal. However, I do not know enough about pwm to know if this will work. My goal would be to control the motor speed through the free software.
Does anyone know if this is would work?
Thanks!
Christopher
