Hi can anyone help? i have bought a ooznest workbee1500x1500mm and i want to use it with easle but there is only the option to set the rail size to a maximum size of 1000mm in machine set up. is there a way to change this to 1500mm
thank you
just pick the 1000 it will work don’t wory a bout it.
The machine size preset during Setup only apply to soft limits end point / range (GRBL Parameter $130-132)
To utilize soft limits the prerequisite is:
- Install homing switches
- Start each power-up with a homing cycle ($H command)
$130-132 can be changed manually at any time.
Just choose the 1000x1000 to get you rolling
