Thanks I saw the mm and switched it and it went to 1hr and 35.
I ran it at the 90% and now I’m doing the 40% which it taking out the parts left from the 90. I did notice that you can see that either the spoil board is uneven or the second was not flat. But once that done it should be even and then I can do a test cut
If you have lines in the skim,then that means your gantry is not perpendicular to your wasteboard
Oh ok is there a way to fix that.
First, if it is very slight bit off just sand the project. If it is bad you will need a square and adjust the gantry at the end points. The square is used to establish the correct perpendicular status
Oh ok. It’s not bad at all but I will check to see if it’s square.
