Help with Vector Art 3D
Has anyone used Vector Art 3D and had any luck importing the G-Code from Vector Art 3D Machinist, if so, would you please e-mail me, I need some guidance in how to do this. pinetoptees@gmail.com I sure would appreciate it.
The company Vectric can help you.
they are very quick response.
They are the ones that make Vcarve
I have not used stuff from there but I make my own and cut my own stuff.
Thank You, I am in touch with them and they are very responsive. Do you have any 3D relief g-code for Carvey that you would like to share, I’m really wanting to test out something to see how my Carvery does with 3D? You can contact me at pinetoptees@gmail.com.
Thanks Don
All I have at the moment is the 3d cut gcode files for the seahorse I did. 100mm x 40mm
If you want you can send me a 3D model file to run though it.
let me know what the bit info is and I can crate a cut gcode for each pass for you to test.
