i have cut out the fish before i don’t know what to do
Definitely a loose pulley or the like on your x-axis. it plots out fine on mine.
Thank you I will look at this.
What did you mean (the like on your x-axis. )??
Is it normal that the pulleys are loose?
Is there a Maintenance list I could download?
Thank you again.
if the belt on your x-axis is super-loose, or the pulley is slipping on the stepper shaft, it could cause that kind of miscue. but I’m not convinced that is it, as it would have screwed up, and hit the home position HARD upon shutting it down…
